LaCie Rugged USB-C Circuit Board Replacement
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: step 1, image 1 of 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: step 1, image 2 of 3 LaCie Rugged USB-C Circuit Board Replacement, Overview: step 1, image 3 of 3
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: step 2, image 1 of 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: step 2, image 2 of 2
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: step 3, image 1 of 2 LaCie Rugged USB-C Circuit Board Replacement, Case Screws: step 3, image 2 of 2
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: step 4, image 1 of 2 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: step 4, image 2 of 2
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: step 5, image 1 of 2 LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: step 5, image 2 of 2
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: step 6, image 1 of 1
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: step 7, image 1 of 1
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: step 8, image 1 of 1
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
5 other people completed this guide.
9021007
4,599 Reputation
25 Guides authored
3 Comments
Where can i get a new board? thank you
Bar Avraham - Reply
Yes, where can we find a new board?
Vassilis Trigkas - Reply
Right, where can the part be purchased?????
James Causey - Reply
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 66
All Time: 1,555
