Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: step 1, image 1 of 1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 2, image 1 of 1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 3, image 1 of 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 3, image 2 of 2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 4, image 1 of 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 4, image 2 of 2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 5, image 1 of 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 5, image 2 of 2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 6, image 1 of 1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 7, image 1 of 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 7, image 2 of 3 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 7, image 3 of 3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 8, image 1 of 1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 9, image 1 of 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 9, image 2 of 2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 10, image 1 of 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 10, image 2 of 2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: step 11, image 1 of 1
    • Gently pull the hose to ensure it is secure.
One Comment
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 784
