Lasko CD08200 Control Panel Replacement
  1. Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: step 1, image 1 of 2 Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: step 1, image 2 of 2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Control Panel Replacement: step 2, image 1 of 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Control Panel Replacement: step 3, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 3, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 3, image 3 of 3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Control Panel Replacement: step 4, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 4, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 4, image 3 of 3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
  5. Lasko CD08200 Control Panel Replacement, Control Panel: step 5, image 1 of 2 Lasko CD08200 Control Panel Replacement, Control Panel: step 5, image 2 of 2
    • Unscrew the four rings using the Phillips #2.
    • Gently remove the fan base from the device.
  6. Lasko CD08200 Control Panel Replacement: step 6, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 6, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 6, image 3 of 3
    • Remove the four 14mm screws using the Phillips #2 screwdriver.
    • Gently detach the control panel from the device.
  7. Lasko CD08200 Control Panel Replacement: step 7, image 1 of 2 Lasko CD08200 Control Panel Replacement: step 7, image 2 of 2
    • Remove the five 14mm screws using the Phillips #2 screwdriver.
    • Pull apart the motherboard from the panel.
  8. Lasko CD08200 Control Panel Replacement: step 8, image 1 of 3 Lasko CD08200 Control Panel Replacement: step 8, image 2 of 3 Lasko CD08200 Control Panel Replacement: step 8, image 3 of 3
    • Remove the three 10mm screws using the Phillips #2 screwdriver.
    • Pull the button from the panel’s top.
    • During reassembly of the top panel, you must align the LED light with the three windows of the top panel and back panel.
Najiib Ahmed
161 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 979
