Lasko CD08200 Fan Replacement
  1. Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: step 1, image 1 of 2 Lasko CD08200 Fan Replacement, Lasko CD08200 Disassembly: step 1, image 2 of 2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Fan Replacement: step 2, image 1 of 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Fan Replacement: step 3, image 1 of 3 Lasko CD08200 Fan Replacement: step 3, image 2 of 3 Lasko CD08200 Fan Replacement: step 3, image 3 of 3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Fan Replacement: step 4, image 1 of 3 Lasko CD08200 Fan Replacement: step 4, image 2 of 3 Lasko CD08200 Fan Replacement: step 4, image 3 of 3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
  5. Lasko CD08200 Fan Replacement, Fan: step 5, image 1 of 2 Lasko CD08200 Fan Replacement, Fan: step 5, image 2 of 2
    • While holding onto the back of the fan housing with one hand and holding the center of the propeller, pull the propeller out.
    • During reassembly, push the propeller and red plate together into the metal shaft until you feel the plate click.
Yonatan Krapivsky
205 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 727
