Lasko Power Plus Box Fan Blade Replacement
  1. Lasko Power Plus Box Fan Blade Replacement, Fan Blade: step 1, image 1 of 1
    • Unplug the box fan.
  2. Lasko Power Plus Box Fan Blade Replacement: step 2, image 1 of 2 Lasko Power Plus Box Fan Blade Replacement: step 2, image 2 of 2
    • Locate the six 16.0 mm Phillips #2 screws around the frame.
    • Use a Philip's #2 bit (PH2) screwdriver to remove them.
  3. Lasko Power Plus Box Fan Blade Replacement: step 3, image 1 of 2 Lasko Power Plus Box Fan Blade Replacement: step 3, image 2 of 2
    • Firmly grasp the front face of the fan. Lift up to remove the face, and set it aside.
  4. Lasko Power Plus Box Fan Blade Replacement: step 4, image 1 of 2 Lasko Power Plus Box Fan Blade Replacement: step 4, image 2 of 2
    • Firmly grasp the base of the blade. Lift up until the blade is removed, exposing the motor.
  5. Lasko Power Plus Box Fan Blade Replacement: step 5, image 1 of 2 Lasko Power Plus Box Fan Blade Replacement: step 5, image 2 of 2
    • Take the new blade and align the center of the base with the motor. Push down on the blade firmly until the blade is secured.
  6. Lasko Power Plus Box Fan Blade Replacement: step 6, image 1 of 1
    • Place the face of the fan back in its original position, making sure to align the holes for the screws.
  7. Lasko Power Plus Box Fan Blade Replacement: step 7, image 1 of 1
    • Use the Phillips #2 bit screwdriver to twist the screws back into place.
Once the frame has been screwed back into place, the fan can now be plugged in and turned on.
Marshall Marburger
145 Reputation
1 Guide authored
2 Guide Comments
I would like to add I had to take off the back and wedge a flat head screw driver between the blades and the motor to gently pry circularly on the two to get the blade off. Pry, turn the blade a turn, pry, turn the blade, until it loosened and came off. My blades were in pretty tight.
Justin - Reply
Where did you get the blades?
mjmjmj -
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 47
All Time: 2,029
