Le Pan II Camera Replacement
  1. Le Pan II Camera Replacement, Screen: step 1, image 1 of 2 Le Pan II Camera Replacement, Screen: step 1, image 2 of 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Camera Replacement: step 2, image 1 of 2 Le Pan II Camera Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Camera Replacement: step 3, image 1 of 2 Le Pan II Camera Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Camera Replacement: step 4, image 1 of 1
    • Remove grey metal backing from screen.
  5. Le Pan II Camera Replacement: step 5, image 1 of 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Camera Replacement: step 6, image 1 of 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Camera Replacement, Camera: step 7, image 1 of 1
    • Use the plastic opening tool to lift the connector up and remove the camera.
Kelly Moniz
525 Reputation
5 Guides authored
UMass Dartmouth, Team 6-3, Martin Fall 2016 Member of UMass Dartmouth, Team 6-3, Martin Fall 2016
UMASSD-MARTIN-F16S6G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 146
