LeapFrog LeapPad Ultimate Battery Replacement
  1. LeapFrog LeapPad Ultimate Battery Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad Ultimate Battery Replacement, Battery: step 1, image 2 of 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Remove the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal both the metal and the plastic spudgers may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Battery Replacement: step 2, image 1 of 1
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use a Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Battery Replacement: step 3, image 1 of 1
    • Remove the back panel of the device exposing the internal components of the device.
    • Once the internal components are exposed locate the point which connects the battery to the motherboard.
  4. LeapFrog LeapPad Ultimate Battery Replacement: step 4, image 1 of 3 LeapFrog LeapPad Ultimate Battery Replacement: step 4, image 2 of 3 LeapFrog LeapPad Ultimate Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • The point connecting the battery and motherboard is made up of three wires, red, white, and black.
    • The plastic portion on the motherboard's end will have a small notch on top. Pull the notch in the direction towards the battery with the curved tweezers. This will disconnect the wires from the motherboard.
  5. LeapFrog LeapPad Ultimate Battery Replacement: step 5, image 1 of 2 LeapFrog LeapPad Ultimate Battery Replacement: step 5, image 2 of 2
    • Carefully remove the battery from the LeapPad, use the plastic spudger to gain leverage, if needed.
3 other people completed this guide.
4 Comments
Does anyone know where I can order a new battery? I can’t find the MH46844 Battery anywhere.
corinnemorrissey - Reply
Did you find this battery..?
mark phillips -
I am also struggling to track down one of these batteries. Can anyone provide any advice on where to look for one?
Neil Paynter - Reply
we disconnected the battery and reconnected and now the leap pad just turns on to the leap start up screen and straight off again continuously any tips on how to stop this?
kayla_dicko - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 75
All Time: 6,121
