LeapFrog LeapPad Ultimate Camera Replacement
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: step 1, image 1 of 2 LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: step 1, image 2 of 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: step 2, image 1 of 2 LeapFrog LeapPad Ultimate Camera Replacement: step 2, image 2 of 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: step 3, image 1 of 1
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: step 4, image 1 of 3 LeapFrog LeapPad Ultimate Camera Replacement: step 4, image 2 of 3 LeapFrog LeapPad Ultimate Camera Replacement: step 4, image 3 of 3
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: step 5, image 1 of 1
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: step 6, image 1 of 2 LeapFrog LeapPad Ultimate Camera Replacement: step 6, image 2 of 2
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: step 7, image 1 of 1
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 228
