LeapFrog LeapPad Ultra XDi Audio Jack Replacement
  1. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement, Battery: step 1, image 2 of 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 2, image 1 of 2 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 2, image 2 of 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 3, image 1 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 3, image 2 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 3, image 3 of 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 4, image 1 of 2 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 4, image 2 of 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 5, image 1 of 2 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 5, image 2 of 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 6, image 1 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 6, image 2 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 6, image 3 of 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
  7. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement, Audio Jack: step 7, image 1 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement, Audio Jack: step 7, image 2 of 3 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement, Audio Jack: step 7, image 3 of 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 8, image 1 of 1
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
  9. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 9, image 1 of 2 LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 9, image 2 of 2
    • Lift the motherboard up to expose the fourth ribbon cable underneath.
    • Flip up the locking clip to release the cable and disconnect the cable from the connector.
  10. LeapFrog LeapPad Ultra XDi Audio Jack  Replacement: step 10, image 1 of 1
    • Locate the headphone jack on the bottom right corner of the motherboard.
    • Use a soldering iron to desolder the five metal connections to the motherboard.
    • Replace the headphone jack.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 273
