LeapFrog LeapPad Ultra XDi Home Button Replacement
  1. LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement, Battery: step 1, image 2 of 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 2, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 2, image 2 of 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 3, image 3 of 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 4, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 4, image 2 of 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 5, image 1 of 2 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 5, image 2 of 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 6, image 3 of 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
  7. LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement, Home Button: step 7, image 3 of 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 1 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 2 of 3 LeapFrog LeapPad Ultra XDi Home Button Replacement: step 8, image 3 of 3
    • Unscrew the four 5mm Phillips #1 screws.
    • Unscrew the two 5mm Phillips #1 screws.
    • Lift the home button circuit board up. Replace the home button circuit board.
    • The entire home button circuit board must be replaced.
    • Do not dispose of rubber padding on home button circuit board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 285
