LeapFrog LeapPad2 Explorer Back Camera Replacement
  1. LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: step 1, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Battery: step 1, image 2 of 2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 1 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 2 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 2, image 3 of 3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: step 3, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Cover: step 3, image 2 of 2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 1 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 2 of 3 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: step 5, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement, Back Camera: step 5, image 2 of 2
    • Locate the back camera below the game cartridge.
  6. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 6, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 6, image 2 of 2
    • To safely remove the ribbon cable, first you must pull up the retaining flap.
    • Removing or reinserting the cable by brute force can damage it.
  7. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 7, image 1 of 2 LeapFrog LeapPad2 Explorer Back Camera Replacement: step 7, image 2 of 2
    • Pull up using a thin plastic tool to disconnect the ribbon connecting the camera to the motherboard.
  8. LeapFrog LeapPad2 Explorer Back Camera Replacement: step 8, image 1 of 1
    • Gently remove the back camera from your motherboard by pushing the black casing away from the camera.
Nupur Garg
867 Reputation
7 Guides authored
Cal Poly, Team 8-10, Regan Spring 2014 Member of Cal Poly, Team 8-10, Regan Spring 2014
CPSU-REGAN-S14S8G10
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,377
