LeapFrog Scribble and Write Display Screen Replacement
  1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: step 1, image 1 of 2 LeapFrog Scribble and Write Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • Turn your toy over.
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  2. LeapFrog Scribble and Write Display Screen Replacement: step 2, image 1 of 1
    • Carefully remove the back of the toy..
  3. LeapFrog Scribble and Write Display Screen Replacement: step 3, image 1 of 2 LeapFrog Scribble and Write Display Screen Replacement: step 3, image 2 of 2
    • Use a Philips screwdriver to remove the two screws attached to the motherboard.
    • Remove the motherboard.
  4. LeapFrog Scribble and Write Display Screen Replacement: step 4, image 1 of 2 LeapFrog Scribble and Write Display Screen Replacement: step 4, image 2 of 2
    • Remove the screen.
    • Remove the two pins from the bottom of the screen.
  5. LeapFrog Scribble and Write Display Screen Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the screw from the green clip that holds the two screen layers together.
  6. LeapFrog Scribble and Write Display Screen Replacement: step 6, image 1 of 2 LeapFrog Scribble and Write Display Screen Replacement: step 6, image 2 of 2
    • Separate the blue and the white films.
    • Clean both films with paper towel.
    • Make sure there are no dirty spots before putting the films back together.
2 other people completed this guide.
Shang
328 Reputation
3 Guides authored
USF Tampa, Team 1-5, Nance Spring 2016 Member of USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 4,825
