LeapFrog Scribble and Write Speaker Replacement
  1. LeapFrog Scribble and Write Speaker Replacement, Speaker: step 1, image 1 of 1
    • Turn your toy over so that the back is facing upward.
  2. LeapFrog Scribble and Write Speaker Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, unscrew all circled areas.
  3. LeapFrog Scribble and Write Speaker Replacement: step 3, image 1 of 1
    • Very carefully, remove the back case to reveal the contents of the toy.
  4. LeapFrog Scribble and Write Speaker Replacement: step 4, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the screw highlighted in the image.
  5. LeapFrog Scribble and Write Speaker Replacement: step 5, image 1 of 1
    • Un-solder the wiring from the speaker and motherboard.
    • Caution: Be careful when using a soldering iron. Improper usage may result in burns.
Anthony Kidd
256 Reputation
2 Guides authored
USF Tampa, Team 1-5, Nance Spring 2016 Member of USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 19
All Time: 764
