Leapfrog LeapPad 3 Front Facing Camera Replacement
  1. Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: step 1, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: step 1, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement, Battery: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 2, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 2, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 2, image 3 of 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 3, image 1 of 2 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 3, image 2 of 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: step 4, image 1 of 2 Leapfrog LeapPad 3 Front Facing Camera Replacement, Speaker: step 4, image 2 of 2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 5, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 5, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 5, image 3 of 3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 6, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 6, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 6, image 3 of 3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
  7. Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: step 7, image 1 of 2 Leapfrog LeapPad 3 Front Facing Camera Replacement, Motherboard: step 7, image 2 of 2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  8. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 8, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 8, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 8, image 3 of 3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  9. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 9, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 9, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 9, image 3 of 3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
  10. Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: step 10, image 1 of 2 Leapfrog LeapPad 3 Front Facing Camera Replacement, Front Facing Camera: step 10, image 2 of 2
    • Unscrew the eight 6.5 mm phillips screws from the plastic casing.
  11. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 11, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 11, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 11, image 3 of 3
    • Remove the covering with your hand to expose the front facing camera.
  12. Leapfrog LeapPad 3 Front Facing Camera Replacement: step 12, image 1 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 12, image 2 of 3 Leapfrog LeapPad 3 Front Facing Camera Replacement: step 12, image 3 of 3
    • Remove the front facing camera from the outer case.
2 other people completed this guide.
Matt Irvine
952 Reputation
6 Guides authored
USF Tampa, Team 16-2, Blackwell Winter 2016 Member of USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 243
