Leapfrog LeapPad 3 Rear Facing Camera Replacement
Matt Irvine
Matt Irvine and 5 other contributors
Last updated on May 7, 2024
50 minutes
Moderate
Introduction
Go to step 1
This guide is rather lengthy as many components must be removed to access the rear facing camera. However, few tools are required and is over all an easy fix.
Tools
Show more…
  1. Leapfrog LeapPad 3 Rear Facing Camera Replacement, Battery: step 1, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement, Battery: step 1, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement, Battery: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 2, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 2, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 2, image 3 of 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 3, image 1 of 2 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 3, image 2 of 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Rear Facing Camera Replacement, Speaker: step 4, image 1 of 2 Leapfrog LeapPad 3 Rear Facing Camera Replacement, Speaker: step 4, image 2 of 2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 5, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 5, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 5, image 3 of 3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 6, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 6, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 6, image 3 of 3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
  7. Leapfrog LeapPad 3 Rear Facing Camera Replacement, Motherboard: step 7, image 1 of 2 Leapfrog LeapPad 3 Rear Facing Camera Replacement, Motherboard: step 7, image 2 of 2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  8. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 8, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 8, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 8, image 3 of 3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  9. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 9, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 9, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 9, image 3 of 3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
  10. Leapfrog LeapPad 3 Rear Facing Camera Replacement, Rear Facing Camera: step 10, image 1 of 2 Leapfrog LeapPad 3 Rear Facing Camera Replacement, Rear Facing Camera: step 10, image 2 of 2
    • Unplug the rear facing camera located in the top center of the motherboard.
  11. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 11, image 1 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 11, image 2 of 3 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 11, image 3 of 3
    • Unhook the small plastic tooth from the underside of the motherboard. This can be accomplished with tweezers.
  12. Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 12, image 1 of 2 Leapfrog LeapPad 3 Rear Facing Camera Replacement: step 12, image 2 of 2
    • Pull the camera out of the top of the motherboard for replacement.
2 other people completed this guide.
Matt Irvine
952 Reputation
6 Guides authored
USF Tampa, Team 16-2, Blackwell Winter 2016 Member of USF Tampa, Team 16-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 223
