Left Temple
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Left Temple, Remove the screw covers: step 1, image 1 of 2 Left Temple, Remove the screw covers: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove the six screw covers from the left temple.
  2. Left Temple, Unfasten the left temple: step 2, image 1 of 2 Left Temple, Unfasten the left temple: step 2, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  3. Left Temple, Remove the outer hinge cover: step 3, image 1 of 3 Left Temple, Remove the outer hinge cover: step 3, image 2 of 3 Left Temple, Remove the outer hinge cover: step 3, image 3 of 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  4. Left Temple, Remove the left temple: step 4, image 1 of 2 Left Temple, Remove the left temple: step 4, image 2 of 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  5. Left Temple: step 5, image 1 of 2 Left Temple: step 5, image 2 of 2
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  6. Left Temple: step 6, image 1 of 2 Left Temple: step 6, image 2 of 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  7. Left Temple: step 7, image 1 of 2 Left Temple: step 7, image 2 of 2
    Tesa 61395 Tape
    $10.95
    Buy
    • The speaker is lightly adhered to the outer temple.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  8. Left Temple, Peel the hinge tape: step 8, image 1 of 2 Left Temple, Peel the hinge tape: step 8, image 2 of 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  9. Left Temple, Unfasten the inner hinge cover: step 9, image 1 of 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.5 mm‑long screw
    • One 4.9 mm‑long screw
  10. Left Temple, Reposition the inner hinge cover: step 10, image 1 of 3 Left Temple, Reposition the inner hinge cover: step 10, image 2 of 3 Left Temple, Reposition the inner hinge cover: step 10, image 3 of 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Rotate the inner hinge cover off its groove in the frame.
    • Let the cover hang off its volume button cable for now.
Alex Diaz-Kokaisl
217,482 Reputation
1,051 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,926 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 87
