Leica Z2X Tripod Socket Replacement
  1. Leica Z2X Tripod Socket Replacement, Remove the Bottom Screws: step 1, image 1 of 1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Tripod Socket Replacement, Open the Back Door: step 2, image 1 of 1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Tripod Socket Replacement, Remove the Bottom Plate: step 3, image 1 of 1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
2 other people completed this guide.
Zachary
46 Reputation
2 Guides authored
Cal Poly, Team 18-19, Garner Spring 2011 Member of Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 2,581
