Lenovo 100e Chromebook 2nd Gen Battery Replacement
  1. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Keyboard: step 1, image 1 of 1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 2, image 1 of 2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 2, image 2 of 2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 3, image 1 of 2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 3, image 2 of 2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 5, image 1 of 1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Battery Replacement: step 6, image 1 of 1
    • The battery is now loose and can be removed from the laptop.
0 Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 143
All Time: 2,513
