Lenovo 100s Chromebook-11IBY Speaker Replacement
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: step 1, image 1 of 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 2, image 1 of 1
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 3, image 1 of 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: step 3, image 2 of 2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 4, image 1 of 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: step 4, image 2 of 3 Lenovo 100s Chromebook-11IBY Speaker Replacement: step 4, image 3 of 3
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 5, image 1 of 1
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 6, image 1 of 2 Lenovo 100s Chromebook-11IBY Speaker Replacement: step 6, image 2 of 2
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: step 7, image 1 of 1
    • Repeat steps 5 & 6 in order to remove the right speaker.
Milton Perez
630 Reputation
5 Guides authored
USF Tampa, Team S7-G2, Cagle Spring 2017 Member of USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Member
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 519
