Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal
  1. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: step 1, image 1 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: step 1, image 2 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove Backplate: step 1, image 3 of 3
    • Turn off your computer.
    • Flip the Chromebook over and unscrew the screws securing the backplate.
  2. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: step 2, image 1 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: step 2, image 2 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing Screws from under laptop: step 2, image 3 of 3
    • Unplug the Battery
    • Unscrew battery and remove
    • Remove all all circled screws
    • I removed the wireless card. I don't know if it's required.
  3. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: step 3, image 1 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: step 3, image 2 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the Keyboard: step 3, image 3 of 3
    • Slide Keyboard up
    • Wedge something under the keyboard
    • flip the keyboard over
    • carefully remove the keyboard ribbon cable
  4. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: step 4, image 1 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: step 4, image 2 of 3 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Removing the Bezel: step 4, image 3 of 3
    • Unscrew and disconnect ribbon cables
    • wedge something between the bezel and slide across the edge until the bezel is lifted (like taking off a bike tire)
  5. Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the write-protect screw: step 5, image 1 of 2 Lenovo 11e ThinkPad Chromebook Write-Protect Screw Removal, Remove the write-protect screw: step 5, image 2 of 2
    • The write-protect screw is clearly conducting electricity (compare it to other screws on the board).
    • Leave the WP screw out of the laptop.
3 other people completed this guide.
Dean Gadberry
176 Reputation
1 Guide authored
2 Comments
Le système software this chromebook
boubker bouchagra - Reply
This chromebook runs ChromeOS. Removing the write-protect screw and running MrChromeBox's Firmware Utility Script allows any linux distribution to run on this chromebook.
Dean Gadberry -
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 281
All Time: 5,172
