Lenovo 300e Chromebook Battery Replacement
  1. Lenovo 300e Chromebook Battery Replacement, Back Cover: step 1, image 1 of 3 Lenovo 300e Chromebook Battery Replacement, Back Cover: step 1, image 2 of 3 Lenovo 300e Chromebook Battery Replacement, Back Cover: step 1, image 3 of 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Battery Replacement: step 2, image 1 of 3 Lenovo 300e Chromebook Battery Replacement: step 2, image 2 of 3 Lenovo 300e Chromebook Battery Replacement: step 2, image 3 of 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Battery Replacement, Battery: step 3, image 1 of 3 Lenovo 300e Chromebook Battery Replacement, Battery: step 3, image 2 of 3 Lenovo 300e Chromebook Battery Replacement, Battery: step 3, image 3 of 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Battery Replacement: step 4, image 1 of 3 Lenovo 300e Chromebook Battery Replacement: step 4, image 2 of 3 Lenovo 300e Chromebook Battery Replacement: step 4, image 3 of 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
To reassemble your device, follow these instructions in reverse order with the new battery.
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 37
All Time: 1,028
