Lenovo 300e Chromebook USB and Charging Ports Replacement
  1. Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: step 1, image 1 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: step 1, image 2 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, Back Cover: step 1, image 3 of 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook USB and Charging Ports Replacement: step 2, image 1 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: step 2, image 2 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: step 2, image 3 of 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: step 3, image 1 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: step 3, image 2 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement, USB and Charging Ports: step 3, image 3 of 3
    • Remove three 5 mm screws from the USB board using a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook USB and Charging Ports Replacement: step 4, image 1 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: step 4, image 2 of 3 Lenovo 300e Chromebook USB and Charging Ports Replacement: step 4, image 3 of 3
    • Detach the white and blue ribbon cable from its cable connector on the USB board.
    • Remove the USB board from the laptop.
One Comment
Do you have same instructions for Lenovo 300e Gen2, I opened and usb ports are soldered with the motherboard, I am having some troubles to replace the usb c, any recommendation?
Juan Raul Hernandez - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 47
All Time: 1,535
