Lenovo 500e Chromebook 2nd Gen Keyboard Replacement
  1. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement, Back Panel: step 1, image 1 of 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 2, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 2, image 2 of 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 3, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 3, image 2 of 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement, Battery: step 4, image 1 of 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 5, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 5, image 2 of 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 6, image 1 of 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement, Motherboard: step 7, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 8, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 8, image 2 of 2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 9, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 9, image 2 of 2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 10, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 10, image 2 of 2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 11, image 1 of 1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 12, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 12, image 2 of 2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 13, image 1 of 3 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 13, image 2 of 3 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 13, image 3 of 3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 14, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 14, image 2 of 2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 15, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 15, image 2 of 2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 16, image 1 of 3 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 16, image 2 of 3 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 16, image 3 of 3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 17, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 17, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 18, image 1 of 1
    • Gently remove the motherboard from the laptop.
  19. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement, Keyboard: step 19, image 1 of 1
    • Remove the three 5 mm screws (six total) from each hinge using a Phillips #0 screwdriver.
  20. Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 20, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Keyboard Replacement: step 20, image 2 of 2
    • Gently open the laptop screen and it will separate from the keyboard.
0 Comments
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 25
All Time: 994
