Lenovo 500e Chromebook 2nd Gen Speakers Replacement
  1. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Back Panel: step 1, image 1 of 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 2, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 2, image 2 of 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 3, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 3, image 2 of 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Battery: step 4, image 1 of 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 5, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 5, image 2 of 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 6, image 1 of 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: step 7, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement, Speakers: step 7, image 2 of 2
    • Remove the two 4 mm screws (one on each speaker) using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 8, image 1 of 2 Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 8, image 2 of 2
    • Use the iFixit opening tool to detach the right speaker cable from the motherboard.
  9. Lenovo 500e Chromebook 2nd Gen Speakers Replacement: step 9, image 1 of 1
    • Remove both speakers by gently pulling them out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 192
