Lenovo B575-1450 Display Panel Replacement
  1. Lenovo B575-1450 Display Panel  Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Display Panel  Replacement: step 2, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 2, image 2 of 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Display Panel  Replacement: step 3, image 1 of 3 Lenovo B575-1450 Display Panel  Replacement: step 3, image 2 of 3 Lenovo B575-1450 Display Panel  Replacement: step 3, image 3 of 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Display Panel  Replacement, Display Panel: step 4, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement, Display Panel: step 4, image 2 of 2
    • Remove both screw covers from the bottom of screen bezel using a plastic spudger. The screws underneath will now be exposed
  5. Lenovo B575-1450 Display Panel  Replacement: step 5, image 1 of 1
    • Using the Phillips #0 Screwdriver, remove the two 4.3 mm screws holding the display to the front bezel.
  6. Lenovo B575-1450 Display Panel  Replacement: step 6, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 6, image 2 of 2
    • Separate the front bezel from the display panel using the plastic opening tool by gently prying around the edges and removing it.
  7. Lenovo B575-1450 Display Panel  Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers carefully disconnect the ZIF connector by pulling cable away from front facing camera that is attached to the back bezel.
  8. Lenovo B575-1450 Display Panel  Replacement: step 8, image 1 of 3 Lenovo B575-1450 Display Panel  Replacement: step 8, image 2 of 3 Lenovo B575-1450 Display Panel  Replacement: step 8, image 3 of 3
    • Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
    • There are two screws in the bottom left and right corners of the frame.
  9. Lenovo B575-1450 Display Panel  Replacement: step 9, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 9, image 2 of 2
    • Using the Phillips #0 Screwdriver, remove the four 2.9 mm screws from each side of the bracket that holds the display panel in place.
  10. Lenovo B575-1450 Display Panel  Replacement: step 10, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 10, image 2 of 2
    • Lay display panel face down on the keyboard.
    • Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
    • Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
  11. Lenovo B575-1450 Display Panel  Replacement: step 11, image 1 of 2 Lenovo B575-1450 Display Panel  Replacement: step 11, image 2 of 2
    • Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
    • Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
    • Pull up on flat wire until display is completely disconnected.
    • Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,611
