Lenovo B575-1450 RAM Replacement
  1. Lenovo B575-1450 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 RAM Replacement: step 2, image 1 of 2 Lenovo B575-1450 RAM Replacement: step 2, image 2 of 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 RAM Replacement: step 3, image 1 of 3 Lenovo B575-1450 RAM Replacement: step 3, image 2 of 3 Lenovo B575-1450 RAM Replacement: step 3, image 3 of 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 RAM Replacement, Back Panel: step 4, image 1 of 2 Lenovo B575-1450 RAM Replacement, Back Panel: step 4, image 2 of 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 RAM Replacement: step 5, image 1 of 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 RAM Replacement: step 6, image 1 of 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 RAM Replacement, RAM: step 7, image 1 of 2 Lenovo B575-1450 RAM Replacement, RAM: step 7, image 2 of 2
    • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
    • Pull the RAM out from the slot.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,472
