Lenovo Edge 15 Battery Replacement
  1. Lenovo Edge 15 Battery Replacement, Battery: step 1, image 1 of 2 Lenovo Edge 15 Battery Replacement, Battery: step 1, image 2 of 2
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Battery Replacement: step 2, image 1 of 2 Lenovo Edge 15 Battery Replacement: step 2, image 2 of 2
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Battery Replacement: step 3, image 1 of 3 Lenovo Edge 15 Battery Replacement: step 3, image 2 of 3 Lenovo Edge 15 Battery Replacement: step 3, image 3 of 3
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Battery Replacement: step 4, image 1 of 2 Lenovo Edge 15 Battery Replacement: step 4, image 2 of 2
    • Gently lift all four corners of the battery to remove it from the laptop.
5 other people completed this guide.
Cody Griffith
321 Reputation
2 Guides authored
Cal Poly, Team S8-G1, Banghart Fall 2017 Member of Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Members
7 Guides authored
2 Comments
Can I recharge a fully drained battery by reseating it?
Linda - Reply
My laptop caught on fire don't recommend
Rahem Gang - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 66
All Time: 8,679
