Lenovo Edge 15 Fan Replacement
  1. Lenovo Edge 15 Fan Replacement, Fan: step 1, image 1 of 3 Lenovo Edge 15 Fan Replacement, Fan: step 1, image 2 of 3 Lenovo Edge 15 Fan Replacement, Fan: step 1, image 3 of 3
    • Turn laptop over and unscrew the eleven M2 x 6.0mm back cover screws with the Phillips #0 screwdriver.
  2. Lenovo Edge 15 Fan Replacement: step 2, image 1 of 2 Lenovo Edge 15 Fan Replacement: step 2, image 2 of 2
    • Gently lift the cover plate off the body of the laptop.
    • Ensure that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Fan Replacement: step 3, image 1 of 2 Lenovo Edge 15 Fan Replacement: step 3, image 2 of 2
    • Unplug the fan connector.
    • Carefully pull out the male header with your fingernails.
    • Avoid pulling on the wire with a lot of force because this could cause the wire to snap off of the connector frame.
  4. Lenovo Edge 15 Fan Replacement: step 4, image 1 of 2 Lenovo Edge 15 Fan Replacement: step 4, image 2 of 2
    • Remove the five M2 x 4.0 mm screws from the heat sink with a Phillips #0 screwdriver.
  5. Lenovo Edge 15 Fan Replacement: step 5, image 1 of 1
    • Gently lift the fan away from the computer.
2 other people completed this guide.
Daniel De Leon
158 Reputation
1 Guide authored
Cal Poly, Team S8-G1, Banghart Fall 2017 Member of Cal Poly, Team S8-G1, Banghart Fall 2017
CPSU-BANGHART-F17S8G1
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,714
