Lenovo Edge 2-1580 RAM Replacement
  1. Lenovo Edge 2-1580 RAM Replacement, Battery: step 1, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement, Battery: step 1, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 RAM Replacement: step 2, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 RAM Replacement: step 3, image 1 of 3 Lenovo Edge 2-1580 RAM Replacement: step 3, image 2 of 3 Lenovo Edge 2-1580 RAM Replacement: step 3, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 RAM Replacement: step 4, image 1 of 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 RAM Replacement, RAM: step 5, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement, RAM: step 5, image 2 of 2
    • Remove the metallic RAM cover
  6. Lenovo Edge 2-1580 RAM Replacement: step 6, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 6, image 2 of 2
    • With both of your thumbs, gently pull both adjacent levers outwards. The RAM module will rise a bit.
  7. Lenovo Edge 2-1580 RAM Replacement: step 7, image 1 of 2 Lenovo Edge 2-1580 RAM Replacement: step 7, image 2 of 2
    • Grab the RAM module , and gently pull it out.
Julian Escallon
714 Reputation
5 Guides authored
USF Tampa, Team S14-G1, Boczar Fall 2017 Member of USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Members
5 Guides authored
2 Comments
What is the Max ram for this, and Can you do one where you replace the screen?
Gary Mike - Reply
but how exactly do i open the cover?
Jestem Bo tak - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,044
