Lenovo Edge 2-1580 Storage Replacement
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: step 1, image 1 of 2 Lenovo Edge 2-1580 Storage Replacement, Battery: step 1, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: step 2, image 1 of 2 Lenovo Edge 2-1580 Storage Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: step 3, image 1 of 3 Lenovo Edge 2-1580 Storage Replacement: step 3, image 2 of 3 Lenovo Edge 2-1580 Storage Replacement: step 3, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: step 4, image 1 of 1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: step 5, image 1 of 2 Lenovo Edge 2-1580 Storage Replacement, Hard drive: step 5, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: step 6, image 1 of 2 Lenovo Edge 2-1580 Storage Replacement: step 6, image 2 of 2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Storage Replacement: step 7, image 1 of 2 Lenovo Edge 2-1580 Storage Replacement: step 7, image 2 of 2
    • Carefully, using your hand, remove the hard drive from the laptop.
5 other people completed this guide.
Julian Escallon
714 Reputation
5 Guides authored
USF Tampa, Team S14-G1, Boczar Fall 2017 Member of USF Tampa, Team S14-G1, Boczar Fall 2017
USFT-BOCZAR-F17S14G1
4 Members
5 Guides authored
3 Comments
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - Reply
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 15
All Time: 4,182
