Lenovo Essential G570 RAM Replacement
  1. Lenovo Essential G570 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to unplug the cable could result in electric shock.
    • Turn the computer upside down.
  2. Lenovo Essential G570 RAM Replacement: step 2, image 1 of 2 Lenovo Essential G570 RAM Replacement: step 2, image 2 of 2
    • Locate the two switches that lock the battery.
    • Push the right switch outwards to unlock the battery.
  3. Lenovo Essential G570 RAM Replacement: step 3, image 1 of 2 Lenovo Essential G570 RAM Replacement: step 3, image 2 of 2
    • Push and hold the left switch outwards to unlock the battery.
    • Pull the battery away from the computer.
  4. Lenovo Essential G570 RAM Replacement, Back Panel: step 4, image 1 of 1
    • Turn the laptop over so that the bottom side is facing up.
  5. Lenovo Essential G570 RAM Replacement: step 5, image 1 of 1
    • Unscrew the five 5mm Phillips #0 screws that hold the cover in place.
    • The screws do not come out fully from the back plate. They stay attached to the plate itself.
  6. Lenovo Essential G570 RAM Replacement: step 6, image 1 of 3 Lenovo Essential G570 RAM Replacement: step 6, image 2 of 3 Lenovo Essential G570 RAM Replacement: step 6, image 3 of 3
    • With the screws removed, insert the plastic opening tool into the groove located on the right side.
    • Begin to pry up, and the plate should lift up from the body of the laptop.
    • While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
  7. Lenovo Essential G570 RAM Replacement, RAM: step 7, image 1 of 1
    • Using your fingers, hold open the two clips holding the top RAM in place.
    • The two RAM chips are placed one on top of another. It is important to take the top one out first to easily access the bottom one.
    • With the clips held away from the RAM, slide the top stick out from it's connection.
  8. Lenovo Essential G570 RAM Replacement: step 8, image 1 of 1
    • With the top RAM stick removed, repeat the same process for the bottom piece. Begin by holding the two clips away from the RAM.
    • With the clips held out, slide the RAM out from the connection.
3 other people completed this guide.
Justin Bickford
476 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 940
