Lenovo Flex 3-1120 Speakers Replacement
  1. Lenovo Flex 3-1120 Speakers Replacement, Bottom Panel: step 1, image 1 of 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Speakers Replacement: step 2, image 1 of 2 Lenovo Flex 3-1120 Speakers Replacement: step 2, image 2 of 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Speakers Replacement: step 3, image 1 of 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Speakers Replacement: step 4, image 1 of 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Speakers Replacement, Speakers: step 5, image 1 of 1
    • Locate the speakers at the bottom left and right corners of the computer.
  6. Lenovo Flex 3-1120 Speakers Replacement: step 6, image 1 of 2 Lenovo Flex 3-1120 Speakers Replacement: step 6, image 2 of 2
    • Locate the two 1mm Phillips head screws on both speakers.
    • Remove both screws from each speaker.
  7. Lenovo Flex 3-1120 Speakers Replacement: step 7, image 1 of 2 Lenovo Flex 3-1120 Speakers Replacement: step 7, image 2 of 2
    • Locate where the two speaker wires join at the center of the computer.
    • Follow the wires directly upward to where they connect into the motherboard.
  8. Lenovo Flex 3-1120 Speakers Replacement: step 8, image 1 of 1
    • Using the spudger, pull the wire down and away from the motherboard to disconnect it.
Geoff Bentz
934 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 422
