Lenovo G40-30 Keyboard Replacement
  1. Lenovo G40-30 Keyboard Replacement, Battery: step 1, image 1 of 3 Lenovo G40-30 Keyboard Replacement, Battery: step 1, image 2 of 3 Lenovo G40-30 Keyboard Replacement, Battery: step 1, image 3 of 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Keyboard Replacement: step 2, image 1 of 3 Lenovo G40-30 Keyboard Replacement: step 2, image 2 of 3 Lenovo G40-30 Keyboard Replacement: step 2, image 3 of 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Keyboard Replacement: step 3, image 1 of 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Lenovo G40-30 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Keyboard Replacement: step 5, image 1 of 2 Lenovo G40-30 Keyboard Replacement: step 5, image 2 of 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Keyboard Replacement: step 6, image 1 of 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Keyboard Replacement: step 7, image 1 of 2 Lenovo G40-30 Keyboard Replacement: step 7, image 2 of 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Keyboard Replacement: step 8, image 1 of 3 Lenovo G40-30 Keyboard Replacement: step 8, image 2 of 3 Lenovo G40-30 Keyboard Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Keyboard Replacement: step 9, image 1 of 1
    • Now your keyboard is free to be replaced!
2 other people completed this guide.
Luke
326 Reputation
1 Guide authored
One Comment
thanks ….terimakasih sangat membantu…..
herman - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 11
All Time: 2,126
