Lenovo G40-30 LCD Screen Replacement
  1. Lenovo G40-30 LCD Screen Replacement, Battery: step 1, image 1 of 3 Lenovo G40-30 LCD Screen Replacement, Battery: step 1, image 2 of 3 Lenovo G40-30 LCD Screen Replacement, Battery: step 1, image 3 of 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 LCD Screen Replacement: step 2, image 1 of 3 Lenovo G40-30 LCD Screen Replacement: step 2, image 2 of 3 Lenovo G40-30 LCD Screen Replacement: step 2, image 3 of 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 LCD Screen Replacement: step 3, image 1 of 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 LCD Screen Replacement, LCD Screen: step 4, image 1 of 2 Lenovo G40-30 LCD Screen Replacement, LCD Screen: step 4, image 2 of 2
    • Use the plastic opening tool to pry the plastic away from the screen.
  5. Lenovo G40-30 LCD Screen Replacement: step 5, image 1 of 2 Lenovo G40-30 LCD Screen Replacement: step 5, image 2 of 2
    • Carefully unsnap the front plastic piece to expose the frame of the screen.
  6. Lenovo G40-30 LCD Screen Replacement: step 6, image 1 of 3 Lenovo G40-30 LCD Screen Replacement: step 6, image 2 of 3 Lenovo G40-30 LCD Screen Replacement: step 6, image 3 of 3
    • Unscrew the four 7mm screws located on all four corners of the frame using a JIS #0 screwdriver.
    • Carefully lift the screen from the base so as to not damage it.
  7. Lenovo G40-30 LCD Screen Replacement: step 7, image 1 of 2 Lenovo G40-30 LCD Screen Replacement: step 7, image 2 of 2
    • Slowly remove the sticker connected to the rear of the screen using a spudger.
    • Carefully disconnect the screen from the base of the laptop.
  8. Lenovo G40-30 LCD Screen Replacement: step 8, image 1 of 1
    • Now you have removed the screen and are ready to install a new one.
2 other people completed this guide.
Jimmy McClenan
156 Reputation
1 Guide authored
2 Comments
Thanks alot…..I just fixed my screen by God's grace.
Nnaemeka Okechukwu - Reply
Hi! Is it possible to replace the screen with 1080p LCD?
Chin Yau Chia - Reply
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 13
All Time: 2,507
