Lenovo G50-80 80E5 Hard Drive Replacement
  1. Lenovo G50-80 80E5 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Hard Drive Replacement: step 2, image 1 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 2, image 2 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 2, image 3 of 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Hard Drive Replacement: step 3, image 1 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 3, image 2 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 3, image 3 of 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Hard Drive Replacement: step 4, image 1 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 4, image 2 of 3 Lenovo G50-80 80E5 Hard Drive Replacement: step 4, image 3 of 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: step 5, image 1 of 2 Lenovo G50-80 80E5 Hard Drive Replacement, Bottom Access Panel: step 5, image 2 of 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Hard Drive Replacement: step 6, image 1 of 2 Lenovo G50-80 80E5 Hard Drive Replacement: step 6, image 2 of 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Hard Drive Replacement, Hard Drive: step 7, image 1 of 1
    • Rotate the laptop until you are positioned over the hard drive.
  8. Lenovo G50-80 80E5 Hard Drive Replacement: step 8, image 1 of 1
    • Use the #00 Phillips screwdriver to remove the four 5.5mm screws around the hard drive.
  9. Lenovo G50-80 80E5 Hard Drive Replacement: step 9, image 1 of 1
    • Slide the hard drive towards yourself and remove it.
If you would like to reassemble your device, please follow these instructions in reverse order.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 776
