Lenovo G50-80 80E5 Power Button Replacement
  1. Lenovo G50-80 80E5 Power Button Replacement, Battery: step 1, image 1 of 1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Power Button Replacement: step 2, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 2, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 2, image 3 of 3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Power Button Replacement: step 3, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 3, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 3, image 3 of 3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Power Button Replacement: step 4, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 4, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 4, image 3 of 3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
  5. Lenovo G50-80 80E5 Power Button Replacement, Bottom Access Panel: step 5, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement, Bottom Access Panel: step 5, image 2 of 2
    • Remove the three screws securing the outer cover of the laptop using a Phillips #0 screwdriver.
  6. Lenovo G50-80 80E5 Power Button Replacement: step 6, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement: step 6, image 2 of 2
    • Slide the cover away from the hinges and lift the panel off.
  7. Lenovo G50-80 80E5 Power Button Replacement, Keyboard: step 7, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement, Keyboard: step 7, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement, Keyboard: step 7, image 3 of 3
    • Locate the 3 screws on the bottom, securing the keyboard.
    • One Screw will be located under Lenovo sticker. Break sticker to gain access to screw.
  8. Lenovo G50-80 80E5 Power Button Replacement: step 8, image 1 of 1
    • Starting on side, gently pry up using spudge.
  9. Lenovo G50-80 80E5 Power Button Replacement: step 9, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement: step 9, image 2 of 2
    • Continue prying around top of keyboard
  10. Lenovo G50-80 80E5 Power Button Replacement: step 10, image 1 of 1
    • Once the top of keyboard is loose, gently lift up
  11. Lenovo G50-80 80E5 Power Button Replacement: step 11, image 1 of 1
    • lift up bottom of keyboard slightly, to access keyboard ribbon
  12. Lenovo G50-80 80E5 Power Button Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, lift up clip to remove keyboard ribbon cable.
  13. Lenovo G50-80 80E5 Power Button Replacement: step 13, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement: step 13, image 2 of 2
    • Keyboard ribbon cable removed
    • Once ribbon is removed, keyboard can be lifted out
  14. Lenovo G50-80 80E5 Power Button Replacement, Removing top panel: step 14, image 1 of 1
    • Remove wifi wires by lifting up
  15. Lenovo G50-80 80E5 Power Button Replacement: step 15, image 1 of 1
    • locate power and monitor cable on bottom side next to fan
  16. Lenovo G50-80 80E5 Power Button Replacement: step 16, image 1 of 1
    Buy
    • remove power cable with tweezers by gently pullying
  17. Lenovo G50-80 80E5 Power Button Replacement: step 17, image 1 of 1
    • remove monitor cable by gently pulling on tab straight up
  18. Lenovo G50-80 80E5 Power Button Replacement: step 18, image 1 of 1
    • Monitor and power cable disconnected
  19. Lenovo G50-80 80E5 Power Button Replacement: step 19, image 1 of 1
    • Disconnect the fan wires from the motherboard by lifting upwards
  20. Lenovo G50-80 80E5 Power Button Replacement: step 20, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 20, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 20, image 3 of 3
    • Locate the 3 screws holding fan in place
    • Remove 3 screws
    • fan should lift out of place
  21. Lenovo G50-80 80E5 Power Button Replacement: step 21, image 1 of 1
    • lift clip to remove ribbon cable for think pad.
  22. Lenovo G50-80 80E5 Power Button Replacement: step 22, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement: step 22, image 2 of 2
    • lift clip to remove power button ribbon cable.
  23. Lenovo G50-80 80E5 Power Button Replacement: step 23, image 1 of 1
    • Begin by locating screws on bottom panel
  24. Lenovo G50-80 80E5 Power Button Replacement: step 24, image 1 of 1
    • Remove screws using a 001 phillips screw driver.
  25. Lenovo G50-80 80E5 Power Button Replacement: step 25, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 25, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 25, image 3 of 3
    • Once screws are removed, begin by gently prying up in one corner using a spudge
    • Continue to center and then around to opposite side.
    • once all sides have been pried open, lift top half off
  26. Lenovo G50-80 80E5 Power Button Replacement: step 26, image 1 of 1
    • Top covered removed
  27. Lenovo G50-80 80E5 Power Button Replacement, Power Button: step 27, image 1 of 2 Lenovo G50-80 80E5 Power Button Replacement, Power Button: step 27, image 2 of 2
    • At this point in disassembly, there will be one #00x5.5 mm screw securing the power button board in place.
    • Take your screwdriver and remove the screw.
  28. Lenovo G50-80 80E5 Power Button Replacement: step 28, image 1 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 28, image 2 of 3 Lenovo G50-80 80E5 Power Button Replacement: step 28, image 3 of 3
    Buy
    • Take your tweezers and grip the power button board.
    • Using tweezers, lift power button board up and out. The cable wire for the power button board should be disconnected at this point and the piece should lift out without any extra work needed.
2 other people completed this guide.
Abigail Hood
387 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 3,586
