Lenovo G575 Fan Replacement
  1. Lenovo G575 Fan Replacement, Fan: step 1, image 1 of 1
    • Use the two switches to the left of and below the battery to unlock and release the battery.
    • The switch on the left should be moved to the left to unlock, then the switch on the right will release the battery.
    • Remove the battery from the laptop by lifting it out from its bay.
  2. Lenovo G575 Fan Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the five screws from the service panel on the right side.
    • Lift up the service panel.
  3. Lenovo G575 Fan Replacement: step 3, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the three silver screws holding the fan down.
    • Pull out the fan cable from its connector on the motherboard.
    • Lift the fan out of the case.
Samson Wong
103 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 876
