Lenovo G70-70 Fan Replacement
  1. Lenovo G70-70 Fan Replacement, Battery: step 1, image 1 of 2 Lenovo G70-70 Fan Replacement, Battery: step 1, image 2 of 2
    • Ensure the battery is removed before attempting to fix anything on the laptop.
    • Orient the laptop so the bottom side is facing you.
    • To unlock the battery, place your thumb over the left switch and slide it to the left.
  2. Lenovo G70-70 Fan Replacement: step 2, image 1 of 2 Lenovo G70-70 Fan Replacement: step 2, image 2 of 2
    • To access the battery, place your thumb over the right switch and slide it to the right.
    • When the battery is unlocked, it will automatically pop up.
  3. Lenovo G70-70 Fan Replacement: step 3, image 1 of 3 Lenovo G70-70 Fan Replacement: step 3, image 2 of 3 Lenovo G70-70 Fan Replacement: step 3, image 3 of 3
    • Remove the battery by lifting it up and away from yourself.
  4. Lenovo G70-70 Fan Replacement, Fan: step 4, image 1 of 3 Lenovo G70-70 Fan Replacement, Fan: step 4, image 2 of 3 Lenovo G70-70 Fan Replacement, Fan: step 4, image 3 of 3
    • Turn your laptop so the bottom side is facing you.
    • Remove two 7.3 mm Phillips #0 screws.
    • Slide the back cover towards yourself.
  5. Lenovo G70-70 Fan Replacement: step 5, image 1 of 3 Lenovo G70-70 Fan Replacement: step 5, image 2 of 3 Lenovo G70-70 Fan Replacement: step 5, image 3 of 3
    • Lift the back cover from the far side towards yourself to remove it.
    • Remove three 6.5 mm screws from the fan using a Phillips #0 screwdriver.
    • The label M2X6 will be located next to each screw.
  6. Lenovo G70-70 Fan Replacement: step 6, image 1 of 3 Lenovo G70-70 Fan Replacement: step 6, image 2 of 3 Lenovo G70-70 Fan Replacement: step 6, image 3 of 3
    • Pinch both sides of the white connector and pull the cord from the socket.
    • Remove the fan from the laptop.
Joseph Crews
842 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 150
