Lenovo G780 Heat Sink Replacement
  1. Lenovo G780 Heat Sink Replacement, Battery: step 1, image 1 of 2 Lenovo G780 Heat Sink Replacement, Battery: step 1, image 2 of 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: step 2, image 1 of 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: step 3, image 1 of 3 Lenovo G780 Heat Sink Replacement, Fan: step 3, image 2 of 3 Lenovo G780 Heat Sink Replacement, Fan: step 3, image 3 of 3
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: step 5, image 1 of 2 Lenovo G780 Heat Sink Replacement: step 5, image 2 of 2
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: step 6, image 1 of 3 Lenovo G780 Heat Sink Replacement, Heat Sink: step 6, image 2 of 3 Lenovo G780 Heat Sink Replacement, Heat Sink: step 6, image 3 of 3
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: step 7, image 1 of 2 Lenovo G780 Heat Sink Replacement: step 7, image 2 of 2
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Riley Griffin
316 Reputation
3 Guides authored
IUPUI, Team S2-G4, Henning Spring 2019 Member of IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 604
