Lenovo G780 Screen Replacement
  1. Lenovo G780 Screen Replacement, Battery: step 1, image 1 of 2 Lenovo G780 Screen Replacement, Battery: step 1, image 2 of 2
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Screen Replacement: step 2, image 1 of 1
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Screen Replacement, Screen: step 3, image 1 of 2 Lenovo G780 Screen Replacement, Screen: step 3, image 2 of 2
    • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
  4. Lenovo G780 Screen Replacement: step 4, image 1 of 3 Lenovo G780 Screen Replacement: step 4, image 2 of 3 Lenovo G780 Screen Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
  5. Lenovo G780 Screen Replacement: step 5, image 1 of 3 Lenovo G780 Screen Replacement: step 5, image 2 of 3 Lenovo G780 Screen Replacement: step 5, image 3 of 3
    • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
    • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
    • Be careful not to break the thin plastic cover.
  6. Lenovo G780 Screen Replacement: step 6, image 1 of 3 Lenovo G780 Screen Replacement: step 6, image 2 of 3 Lenovo G780 Screen Replacement: step 6, image 3 of 3
    • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
  7. Lenovo G780 Screen Replacement: step 7, image 1 of 2 Lenovo G780 Screen Replacement: step 7, image 2 of 2
    • With the back cover being removed from the screen frame, the back cover can be set aside.
  8. Lenovo G780 Screen Replacement: step 8, image 1 of 3 Lenovo G780 Screen Replacement: step 8, image 2 of 3 Lenovo G780 Screen Replacement: step 8, image 3 of 3
    • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
    • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
  9. Lenovo G780 Screen Replacement: step 9, image 1 of 3 Lenovo G780 Screen Replacement: step 9, image 2 of 3 Lenovo G780 Screen Replacement: step 9, image 3 of 3
    • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
    • With the screws removed the screen will be free to be lifted away from the screen frame.
Riley Griffin
316 Reputation
3 Guides authored
IUPUI, Team S2-G4, Henning Spring 2019 Member of IUPUI, Team S2-G4, Henning Spring 2019
IUPUI-HENNING-S19S2G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 996
