Lenovo Horizon 2s HDD Replacement
  1. Lenovo Horizon 2s HDD Replacement, Rear Case: step 1, image 1 of 3 Lenovo Horizon 2s HDD Replacement, Rear Case: step 1, image 2 of 3 Lenovo Horizon 2s HDD Replacement, Rear Case: step 1, image 3 of 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s HDD Replacement: step 2, image 1 of 2 Lenovo Horizon 2s HDD Replacement: step 2, image 2 of 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s HDD Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s HDD Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s HDD Replacement: step 5, image 1 of 3 Lenovo Horizon 2s HDD Replacement: step 5, image 2 of 3 Lenovo Horizon 2s HDD Replacement: step 5, image 3 of 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s HDD Replacement, HDD: step 6, image 1 of 2 Lenovo Horizon 2s HDD Replacement, HDD: step 6, image 2 of 2
    • Using your Philips head screw driver with the number 1 head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  7. Lenovo Horizon 2s HDD Replacement: step 7, image 1 of 1
    • Now carefully lift the hard-drive that is still attached to the boot from the rear casing.
  8. Lenovo Horizon 2s HDD Replacement: step 8, image 1 of 2 Lenovo Horizon 2s HDD Replacement: step 8, image 2 of 2
    • Now that the hard-drive is detached from the rear casing you will still have to detach the hard-drive from its boot. Again using the Philips screwdriver with the number one head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  9. Lenovo Horizon 2s HDD Replacement: step 9, image 1 of 1
    • Now that the screws are detached. You can now carefully lift the hard-drive from the metal boot.
2 other people completed this guide.
Zak Kazakos
320 Reputation
3 Guides authored
USF Tampa, Team S3-G6, Cannon Fall 2017 Member of USF Tampa, Team S3-G6, Cannon Fall 2017
USFT-CANNON-F17S3G6
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 27
All Time: 5,085
