Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: step 1, image 1 of 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 2, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 2, image 2 of 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: step 3, image 1 of 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 4, image 1 of 3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 4, image 2 of 3 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 4, image 3 of 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 5, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 5, image 2 of 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: step 6, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: step 6, image 2 of 2
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 7, image 1 of 1
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 8, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 8, image 2 of 2
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: step 9, image 1 of 1
    • Lift the hard drive up to remove it from the enclosure.
12 other people completed this guide.
Jackson Blake
1,119 Reputation
9 Guides authored
Cal Poly, Team S16-G3, Banghart Winter 2018 Member of Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Members
9 Guides authored
5 Comments
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - Reply
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - Reply
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - Reply
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 62
All Time: 16,087
