Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement
  1. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Stand Base: step 1, image 1 of 1
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 2, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 2, image 2 of 2
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Back Cover: step 3, image 1 of 1
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 4, image 1 of 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 4, image 2 of 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 4, image 3 of 3
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 5, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 5, image 2 of 2
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: step 6, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, Arm Stand: step 6, image 2 of 2
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 7, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 7, image 2 of 2
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: step 8, image 1 of 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: step 8, image 2 of 3 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, EMI Cover: step 8, image 3 of 3
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: step 9, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement, WiFi Card: step 9, image 2 of 2
    • Remove any tape that secures the WiFi antenna cables.
  10. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 10, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 10, image 2 of 2
    • Remove the single screw that secures that WiFi card to the motherboard.
  11. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 11, image 1 of 2 Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 11, image 2 of 2
    • Lift the wifi card and then pull out the card.
  12. Lenovo IdeaCentre AIO 510S-23ISU WiFi Card Replacement: step 12, image 1 of 1
    • Locate the two small cables connected to the wifi card and pull gently to disconnect them.
2 other people completed this guide.
Jackson Blake
1,119 Reputation
9 Guides authored
Cal Poly, Team S16-G3, Banghart Winter 2018 Member of Cal Poly, Team S16-G3, Banghart Winter 2018
CPSU-BANGHART-W18S16G3
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,602
