Lenovo IdeaCentre K410 CPU Fan Replacement
  1. Lenovo IdeaCentre K410 CPU Fan Replacement, Side Panel: step 1, image 1 of 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Fan Replacement: step 2, image 1 of 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Fan Replacement, CPU Fan: step 3, image 1 of 1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 CPU Fan Replacement: step 4, image 1 of 1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
Timothy Grebe
1,634 Reputation
9 Guides authored
Cal Poly, Team 10-39, Amido Fall 2014 Member of Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,294
