Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement
  1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Back Case: step 1, image 1 of 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 2, image 1 of 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 2, image 2 of 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 3, image 1 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 3, image 2 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 3, image 3 of 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 4, image 1 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 4, image 2 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 4, image 3 of 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Battery Replacement: step 5, image 1 of 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 6, image 1 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 6, image 2 of 3 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 6, image 3 of 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: step 7, image 1 of 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: step 7, image 2 of 2
    • Detach the speaker wire from the motherboard.
  8. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 8, image 1 of 2 Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: step 8, image 2 of 2
    • Gently pull upwards on the speaker assembly to remove it from the case.
Clark Beuckman
544 Reputation
5 Guides authored
Clemson, Team 2-3, Hunter Spring 2022 Member of Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 164
