Lenovo IdeaPad 110-15ISK Motherboard Replacement
  1. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Keyboard: step 1, image 1 of 1
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 2, image 1 of 1
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 3, image 1 of 1
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Optical Drive: step 5, image 1 of 1
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 6, image 1 of 1
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Upper Case: step 7, image 1 of 1
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 8, image 1 of 1
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
  8. Lenovo IdeaPad 110-15ISK Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Pull the two connectors with blue ribbons marked with MB in the opposite direction of the connector
  9. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 10, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the marked four 4.0mm screws.
    • Pull out the hard drive.
  10. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 11, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the five 4.0mm screws.
  11. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, pull the four marked connectors out and away from the motherboard.
    • Remove the WIFI card by pulling up and away from the motherboard.
  12. Lenovo IdeaPad 110-15ISK Motherboard Replacement: step 13, image 1 of 1
    • Pull off the motherboard.
2 other people completed this guide.
Jakub Szark
513 Reputation
5 Guides authored
UW Tacoma, Team S1-G5, Rose Fall 2018 Member of UW Tacoma, Team S1-G5, Rose Fall 2018
UWT-ROSE-F18S1G5
4 Members
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 4,260
