Lenovo IdeaPad 110-171KB Battery Replacement
  1. Lenovo IdeaPad 110-171KB Battery Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaPad 110-171KB Battery Replacement, Battery: step 1, image 2 of 2
    • Insert an opening pick between the chassis and keyboard.
    • Gently slide the pick around the perimeter of the keyboard while prying until it releases completely.
    • Remove the keyboard.
  2. Lenovo IdeaPad 110-171KB Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad 110-171KB Battery Replacement: step 2, image 2 of 2
    • Disconnect the cable connector from the motherboard.
    • Slide the cable out of the case.
  3. Lenovo IdeaPad 110-171KB Battery Replacement: step 3, image 1 of 1
    • Place the the computer bottom facing up. Unscrew the eleven Phillips #0 6 mm screws.
  4. Lenovo IdeaPad 110-171KB Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad 110-171KB Battery Replacement: step 4, image 2 of 2
    • Pry the disk drive opposite of the laptop.
    • Since the screws has already been removed, you will not need to worry about any more screws on the optical drive.
  5. Lenovo IdeaPad 110-171KB Battery Replacement: step 5, image 1 of 2 Lenovo IdeaPad 110-171KB Battery Replacement: step 5, image 2 of 2
    • Release any of the remaining retaining clips and remove the lower case.
  6. Lenovo IdeaPad 110-171KB Battery Replacement: step 6, image 1 of 3 Lenovo IdeaPad 110-171KB Battery Replacement: step 6, image 2 of 3 Lenovo IdeaPad 110-171KB Battery Replacement: step 6, image 3 of 3
    • Remove the two 9 mm Phillips #0 screws that secure the battery.
    • Remove the battery from the device.
Cameron Mounce
668 Reputation
5 Guides authored
Gateway, Team 1-3, Pee Fall 2023 Member of Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 98
