Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: step 1, image 1 of 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 2, image 2 of 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 3, image 2 of 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 4, image 1 of 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 4, image 2 of 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 4, image 3 of 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 6, image 1 of 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 6, image 2 of 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 7, image 1 of 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: step 8, image 1 of 1
    • Remove the hard drive from the housing mount.
Cameron Mounce
668 Reputation
5 Guides authored
Gateway, Team 1-3, Pee Fall 2023 Member of Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 143
