Lenovo IdeaPad 110-17IKB Lower Case Replacement
  1. Lenovo IdeaPad 110-17IKB Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 2, image 1 of 2 Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 2, image 2 of 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 3, image 1 of 2 Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 3, image 2 of 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 4, image 1 of 3 Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 4, image 2 of 3 Lenovo IdeaPad 110-17IKB Lower Case Replacement: step 4, image 3 of 3
    • Release the remaining clasp and remove the lower case.
Cameron Mounce
668 Reputation
5 Guides authored
Gateway, Team 1-3, Pee Fall 2023 Member of Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 103
