Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement
  1. Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement, Back Cover: step 1, image 1 of 3 Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement, Back Cover: step 1, image 2 of 3 Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement, Back Cover: step 1, image 3 of 3
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Orient the laptop so that the bottom is facing up.
    • Remove the six 7 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4 mm screws using a Phillips #00 screwdriver.
  2. Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement: step 2, image 1 of 3 Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement: step 2, image 2 of 3 Lenovo IdeaPad 3-1481W000NGUS Back Cover Replacement: step 2, image 3 of 3
    • Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
    • You may hear snapping when removing the panel. This is normal!
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 205
